I am using V.83.
Test Motors works fine, then I goto calibration, and tell it to move 1000mm left.
Python shows the command, but nothing happens.
Have rebooted, reinstalled, and powered down still no movement?
Have you been through the Actions/Calibrate Machine Dimensions yet? Go through each of those steps, and after that you’ll have more control because the machine will have learned its configuration.
Having no luck with the Calibrate machine dimensions sprocket will not move, except when doing encoder testing
Python showing commands are being sent
Python isn’t showing the responses, though. Check to see that the Arduino IDE isn’t running. If it is, quit both that and GC, and restart GC.
double post: No Chain Movement during Calibration
