Quite often, the extend all function does not work logically: the motor holds the belt instead of accompanying it. Today it is, but yesterday it was not. I then have to push the belt inwards so that the machine gives me some slack.
I own thé Maslow 4 from the kickstarter.
https://forums.maslowcnc.com/t/motors-running-backwards-on-extend-all/22075 same issue.
The problem is that it is too small to solder…
DM me your address and I will send you some which are soldered!
Allfours work just fine! Thanks!
