I’d like to be able to make cuts/carve without being restricted to maintaining a flat surface (on the workpiece) for the sled to slide across. With the machine as-is, I would expect to be restricted to working on pieces no wider or longer than being just shy of the radius of the sled.
My first thought was a gantry that would attach to the sled and the vertical axis being under the belts while the horizontal axis was above them. Would have to modify frame and maslow itself, and it’d be a significant design/cost investment.
That made me consider taking advantage of the sled sliding and building a metal trough just slightly wider than the sled for it to slide up and down and putting it on rails attached above and below the mounting board, reducing the cost and making it so I can just pop the sled out of the trough and it’d be much easier to take the mechanism off the frame when it isn’t wanted.
My second thought was supporting the sled on slats resting above the workpiece and only cutting between the slats, while also doing the overall carve in 2 separate g code files where the first cuts where the slats aren’t, initially, and the second cuts where they used to be, after you slide them over to a now-safe area. Other than needing to make sure to provide contact points to keep the sled flat at all times, build frames for each carve, and losing the thickness of the slats from the max depth of your carve, this seems like a pretty solid path.
A rough example of the idea/process:
- build support frame around piece to cut for sled
- carve exposed areas between supports
- move supports
- carve material that was previously under supports
Just grabbed a random file from SketchUp’s library to use for the “terrain” visual.
((will need to have wider supports on the outer edges, of course))
Thinking towards simplifying the process, I had an idea relative to how many people build tables for flattening slabs manually, with a wooden trough that acts as a gantry. If the same process was used as the slats idea, but only using 2 supports, and the cut was done a single stripe at a time, the jig, while needing updated more times per overall carve, becomes much easier to manage.
