My first two cuts on the Maslow are complete. and I was expecting a little more distortion however, everything basically turned out fine.
My questions. First is there a way to set a given location as zero on the frame? i’d like to move the head to the corner and then set that as zero for the source of the cut.
The second question… I normally use Vcarve pro as my gcode generator, however, I was receiving errors when using that code with ground control, anyone know what the best gcode output method is for GC support?
You should be able to move the home position of the cut by using the “Define Home” button over on the right hand side of Ground Control. What it will do is to define the (0,0) point in v-carve as the current sled location.
I haven’t personally used vcarve pro, but I think some others have used it successful…does anyone have advice?
Great work. My understanding is in GC wherever you hit the define home button, the current location will be the point of origin. I plan to have a reference point in my sled for this purpose, a workflow that is repeatable. I don’t think GC has a set “original point of origin”, it’s all user defined.
I can’t answer the second question at this time. I suspect it is unsupported G-codes. Can you share your file here?
Don’t know if you have options in v-carve for post processors?
I have used 2, LinuxCnc and Grbl so far with the Maslow and both cut well. Unknown commands are just ignored.
Would interest me too. What post processor are our Fusion 360 Maslowians using?
I did a quick check on the wiki and did not find anything. It could be of general interest to have a list of post processors that have been tested and related error popups.
I’ve been using the Grbl post and it works great for me. The list is quite extensive, so it’s a bit overwhelming when you first look at it. These are only some of the options (the Grbl is the highlighted one):
Until we maybe end up with a MaslowCNC custom post-processor, the only reasonable options here are either the included GRBL post processor OR, a modified one which purports to improve the included post processor that I found on Github.
I have no experience with either at the moment, but this seems to be the only reasonable options at this time. (ie: maslowCNC is attempting to maintain GRBL compatibility, and these options purport to optimize for GRBL compatibility.)
It looks to me like you’re using the Boxzy post processor, Boxzy is a multi function 3D Printing/ Laser Engraving and Milling machine.
While this might work just fine as you are presumably only using the milling output available in Fusion360, it probably allows for other output not capable of interpretation by a MaslowCNC. This would require a series of missteps by the user, but isn’t ‘impossible’.
I’d recommend using either the Post Processor linked above or the ‘grbl.cps’ post processor in the list shown in your screenshot. (which is the correct ‘built in’ grbl post processor to use I believe.
as I said above tho, I’ve not yet any hands on experience, so YMMV. good luck!
Woops, my bad, I didn’t even notice. Maybe I should attach an extruder and make my Maslow a multi-function machine! And we thought our math was hard now o.O
I’ve been running all my programs using that post. I thought the code was a little bare-bones, but I haven’t had any issues with programs.
I switched over the output and noticed that the way the code looks much more like a traditional CNC router code. I did notice that it make all my arcs G2/G3 cuts instead of segmented G1 cuts. It also added M codes, which is very nice.
I think either post would work, but I definitely agree that using the standard Grbl is better.
Thanks for all of the input, I was able to get things working, by simply renaming the Gcode arc files I normally use from .tap to .nc
Next question, I was able to get target destination sorted out and move around my cuts to the correct place. Now is there any way to get them to refresh on screen? I was able to easily run the cut, but I don’t see any on screen display. Thoughts/ideas?
The clear part is Ridgid part#513349001, pretty inexpensive. I can’t remember where I got the 1.25" to 2.25" vacuum adapter. I tried one of these kits, but the hose is heavy and the slip-on fitting slips off the router as it moves about.
If you are not seeing a preview of the Gcode I’d say that’s a bug and we need to fix it. @Gero’s example of what could be going on is a great one but we would need to take a look at the code to be sure
As for hose adapters I recommend CNCing one Here’s how I did mine:
The code you attached does not have spaces in it like @Gero had suggested, so I’m guessing that’s what the problem is. Can’t speak from experience, but I could plug it into my machine when I get home to see if I can replicate the issue.
