well I would email etomn, the manufacturer and see if they will sell you a replacement gear. they are probablay worth 10 cents in china or ask bar if he has any spares?
Sounds like we all need a few spares…
how is the gear box held onto the round motor?
edited to add. the gear box is held on with two phillips screws, took mine apart to see.
You can get spare motors -
Also there are gear scripts for openscad.
If you print a gear let me know how it works.
I just ordered a spare motor I’m tempted to make a silicone cast so we could make replacements. Honestly I don’t have the time.
Anyone here good wit silicone? Mike you know anyone through work? The reason to choose silicone is you could do resin or metal - I’d do at least 5 molds. You still have a good gear on the opposite side?
Just thinking out loud
Has Anyone else with stripped Gearbox opened it up?
Is this always the same gear that fails?
Yes others have stripped the gear -
Here is some good info on the motor -
Whats inside the gearbox/motor?
I reached out to the motor manufacture that shows a North American distribution point. When I asked them about buying from them they admitted they don’t have North American location and said I need to buy from Bar.
I’m still weighing options to see if we will offer a kit - the kit has wondered from $300 to an upcoming $600.
I always wanted a more plug n play solution. I would like to see a more 3d printer like solution. Touchscreen computer built in ready to run just add lumber.
I think a full kit with router, on board computer, again just add frame would be a reasonable @ $1000.
Just a few thoughts
Newbie question.
Stepper motors such as the nema 23 or 34 won’t work because they basically shift into neutral when they are not actively turning? And is the speed not controllable with out the gearing?
I’m sure someone else can answer better then I can. However there are options to use stepper motors but many good ones to not use them. Stepper motors are “ON” or “OFF” the behavior is the opposite of what we get with these motors. When power is lost the motors hold the sled, with a stepper loss of power would let the sled freefall. Steppers typically are “dumb” devices, it’s assumed they followed the signals given. Steppers with encoders are quite expensive. There is more to it but this covers the basic problems I believe.
I definitely know people that could cast this no problem. But how do we get it to metal from a silicone mold? We’re about to make a bunch of molds so if there is a way to make this happen I’m totally game.
I have the good motor and I just ordered 3 more last night. Thinking I might try to get a second Maslow on the go with the spare shield and mega you gave me.
Might try to get a sled laser cut too. I really like that idea for maximum percision
I’m gong to try a MDF sled on a precision CNC when I get a chance. I also want a Acrylic laser cut sled. I have made 2 sleds and feel making it by hand is by far the fastest solution.
Silicone can withstand some wicked heat so I think you could do aluminum casting or pot metal. Metal gears might make something else break but whatever.
I was / am getting a Maslow together for the UK office. I got 2 motors and Z kit from Maslow. A little disappointed that the motor cables were not included as I had ordered the same thing in the past and they were. It must have to do with shutting down. I was able to get 1 set of gears , a set of motor cables, and a UK power supply from the surplus site. I can fake everything else. I think my total cost to get it together was $320. Of course we don’t need shields - lol
Keep me in the loop on molds please. We can go PM on this too.
The inside of my gearbox looks different than what is pictured here…
I wonder why that is?
please post pictures.
I already did. They are like 4 comments up
Wait a minute … I’m pretty sure this top sprocket doesn’t do anything …
They are posted above. I just realized that it looks the same if you remove the top sprocket from the double sprocket.
They must’ve ran out and used this in a pinch
EDIT : nevermind … that sprocket is def important … it transfers power to the axl hahah
i am surprised your metal gears were destroyed instead of the plastic gear. I thought the whole point of using the plastic gear was that it would self destruct first. basically acting as the weak link in the chain of gears.
I believe all the other gear box failures were with the plastic gear. the plastic gear is the first gear to rotate so it gets the direct power from the motor.
Part of the problem (at least for me) is the stock lubrication (or lack there-of) in the gearboxes. It is woefully inadequate given the application. The picture of the gearbox shows very little if any grease remaining. A little smear of white lithium grease is not going to be enough given the hours of continuous use these motor/gearboxes are seeing. What is applied by the manufacturer will very quickly either evaporate or be slung off onto the inside walls of the gearbox. Once the gears are dry they will overheat and wear, fail, and the broken teeth will further damage the remaining gears.
Possible solution is to pack the gearboxes with a light weigt bearing grease. No more than 3/4 full. Not sure if this idea has been tested before. After seeing the photo, its something I am going to test on mine.
I’m 3D printing a petG one right now as a test. Going to a CNC machine shop at lunch to check out getting them to mill one
Please do follow up with us!
I suspect you are right, at least in principle.
Do you think the gearbox is sealed? Maybe it is tight enough to use a lighter weight lube?
Well … haha … The petG printed sprocket worked beautifully … for like 30 seconds…
haha then it had the same failure as the real one.
When a load was applied we lost our teeth.
