Then it converted to Gcode. The first time I put it into ground control my design was the But I had to make some changes to the cut. The Z axis was topping out so I had to readjust it in the program.
After making changes when i load it to ground control I see this
I’m not sure why it’s not showing up in Ground Control, but when look at your gcode on https://ncviewer.com/ it looks like your gcode isn’t quite right. The bottom right circle is all messed up. I’m assuming all of the "T"s in your screenshot are tabs, but the gcode has no tabs in the circles and it’s missing the tab on the bottom of the square.
Thanks for looking at it, I will start over. I tried to open the sled on ground control and I don’t see the sled either.
Is it possible that I turned something off.
There shouldn’t be anything that you can turn off to make files not show up. Pressing the “define home” button might be a good idea to make sure the home position isn’t off screen or something
