When I load g-code I see no parts only a few dotted lines. Trying to cut my final sled.
Pulled into 2 different computers, same result. Running latest version.
No problems in makercam
Are you using a gcode file that you created? Itâs possible that there was a step or two missed in the process of creating the gcode file. It would be easier to tell by looking at the file. Unfortunately, I think new members canât attach files to their posts for the first day or two, but maybe you could copy the first 20 or 30 lines from the gcode file and paste them into a post?
Its all just gotoâs, no operations. I made my own and used the svg from the sled files. Is it not exporting the paths from Makercam?
I opened the file in the downloads âNew sled with toolpathsâ and that shows correctly. Not sure what is happening with new files though.
Thatâs it. Go back through the MakerCam instructions, and make sure that objects are selected when doing the steps.
They were all highlighted in each operation, It added tabs fine. Calculated okay. It seems like it is something else. I did it 3 times with the instructions up and it looked just like the exampleâŠ
Itâs a puzzler for sure! If the âtarget depthâ value or the âtool diameterâ value were zero, or if no profiles were selected in this step then there wouldnât be any cutting to be calculated.
Gonna reboot, breath deep and try again. Iâll let you know.
Reinstalled ground control using source and it works, go figure.
Thanks for the update!
Final sled cut with 3/32 of round and about a 1/16 undersized. Real happy with first result. Now to get tweaking
within 3/32
