Ross
1
I have installed the Metal Maslow Z Axis Up Grade but do not know WHAT Negative Number to use in the software for the Z Axis PITCH.
If it is 4X faster then basically Rounded, 3x4 =12 Nope.
Way off.
6 is Closer
I’ve called and text Metal Maslow…No Response
Can someone PLEASE Help with this Correct Value???
Orob
2
I believe the number is 8
-8 is the pitch of the threaded rod if you are using the sled with c beam.
Dont have any Idea why but my z axis pitch has to be set at 25 to get it to cut accurately. nuts right… but that’s what works.
Arnd
5
He sells different motors and different spindles. Therefore the value can differ greatly. Mine is 110 if i remember correctly.
