I was attempting to test the Holey Triangulation Calibration but I’m getting hung up when I click Holey Calibration. By hung up I mean, GC closes. Any Ideas?
Kivy Log
[INFO ] Logger: Record log in C:\Users\patri.kivy\logs\kivy_19-08-18_3.txt
[INFO ] deps: Successfully imported “kivy_deps.glew” 0.1.12
[INFO ] deps: Successfully imported “kivy_deps.sdl2” 0.1.22
[INFO ] Kivy: v1.11.1
[INFO ] Kivy: Installed at “C:\Python27\lib\site-packages\kivy_init_.pyc”
[INFO ] Python: v2.7.10 (default, May 23 2015, 09:44:00) [MSC v.1500 64 bit (AMD64)]
[INFO ] Python: Interpreter at “C:\Python27\python.exe”
[WARNING] Deprecated: Python 2 Kivy support has been deprecated. The Kivy release after 1.11.0 will not support Python 2 anymore
[INFO ] Factory: 184 symbols loaded
[INFO ] Image: Providers: img_tex, img_dds, img_sdl2, img_pil, img_gif (img_ffpyplayer ignored)
[INFO ] Window: Provider: sdl2
[INFO ] GL: Using the “OpenGL” graphics system
[INFO ] GL: GLEW initialization succeeded
[INFO ] GL: Backend used
[INFO ] GL: OpenGL version <4.5.0 - Build 23.20.16.5044>
[INFO ] GL: OpenGL vendor
[INFO ] GL: OpenGL renderer <Intel® UHD Graphics 620>
[INFO ] GL: OpenGL parsed version: 4, 5
[INFO ] GL: Shading version <4.50 - Build 23.20.16.5044>
[INFO ] GL: Texture max size <16384>
[INFO ] GL: Texture max units <32>
[INFO ] Window: auto add sdl2 input provider
[INFO ] Window: virtual keyboard not allowed, single mode, not docked
[INFO ] Text: Provider: sdl2
[INFO ] Base: Start application main loop
[INFO ] GL: NPOT texture support is available
[INFO ] GL: Unpack subimage support is available
[INFO ] Base: Leaving application in progress…
[WARNING] stderr: Traceback (most recent call last):
[WARNING] stderr: File “C:\Users\patri\Desktop\Holey GC\GroundControl-master\main.py”, line 512, in
[WARNING] stderr: GroundControlApp().run()
[WARNING] stderr: File “C:\Python27\lib\site-packages\kivy\app.py”, line 855, in run
[WARNING] stderr: runTouchApp()
[WARNING] stderr: File “C:\Python27\lib\site-packages\kivy\base.py”, line 504, in runTouchApp
[WARNING] stderr: EventLoop.window.mainloop()
[WARNING] stderr: File “C:\Python27\lib\site-packages\kivy\core\window\window_sdl2.py”, line 747, in mainloop
[WARNING] stderr: self._mainloop()
[WARNING] stderr: File “C:\Python27\lib\site-packages\kivy\core\window\window_sdl2.py”, line 479, in _mainloop
[WARNING] stderr: EventLoop.idle()
[WARNING] stderr: File “C:\Python27\lib\site-packages\kivy\base.py”, line 339, in idle
[WARNING] stderr: Clock.tick()
[WARNING] stderr: File “C:\Python27\lib\site-packages\kivy\clock.py”, line 591, in tick
[WARNING] stderr: self._process_events()
[WARNING] stderr: File “kivy_clock.pyx”, line 384, in kivy._clock.CyClockBase._process_events
[WARNING] stderr: File “kivy_clock.pyx”, line 414, in kivy._clock.CyClockBase._process_events
[WARNING] stderr: File “kivy_clock.pyx”, line 412, in kivy._clock.CyClockBase._process_events
[WARNING] stderr: File “kivy_clock.pyx”, line 167, in kivy._clock.ClockEvent.tick
[WARNING] stderr: File “C:\Users\patri\Desktop\Holey GC\GroundControl-master\CalibrationWidgets\computeCalibrationSteps.py”, line 27, in loadNextStep
[WARNING] stderr: self.readyToMoveOn()
[WARNING] stderr: File “C:\Users\patri\Desktop\Holey GC\GroundControl-master\CalibrationWidgets\calibrationFrameWidget.py”, line 376, in loadNextStep
[WARNING] stderr: self.loadStep(self.currentStepNumber)
[WARNING] stderr: File “C:\Users\patri\Desktop\Holey GC\GroundControl-master\CalibrationWidgets\calibrationFrameWidget.py”, line 402, in loadStep
[WARNING] stderr: self.currentWidget.on_Enter()
[WARNING] stderr: File “C:\Users\patri\Desktop\Holey GC\GroundControl-master\CalibrationWidgets\adjustZCalibrationDepth.py”, line 24, in on_Enter
[WARNING] stderr: if int(self.data.config.get(‘Maslow Settings’, ‘zAxis’)) == 1:
[WARNING] stderr: ValueError: invalid literal for int() with base 10: ‘0.0’
