I’ve managed to get a decent calibration on my non standard frame, finally.
Just before I had to leave the workshop this morning, I thought I’d have a go at cutting a gcode file, so I used the ‘Open File’ button. GC crashed, and it wasn’t a one-off. The crash message is here:
[INFO ] Kivy v1.8.0[INFO ] [Logger ] Record log in /root/.kivy/logs/kivy_17-08-19_3.txt[INFO ] [Factory ] 157 symbols loaded[DEBUG ] [Cache ] register <kv.lang> with limit=None, timeout=Nones[DEBUG ] [Cache ] register <kv.image> with limit=None, timeout=60s[DEBUG ] [Cache ] register <kv.atlas> with limit=None, timeout=Nones[INFO ] [Image ] Providers: img_tex, img_dds, img_pygame, img_pil, img_gif [DEBUG ] [Cache ] register <kv.texture> with limit=1000, timeout=60s[DEBUG ] [Cache ] register <kv.shader> with limit=1000, timeout=3600s[DEBUG ] [Window ] Ignored <egl_rpi> (import error)[INFO ] [Window ] Provider: pygame([‘window_egl_rpi’] ignored)[DEBUG ] [Window ] Display driver x11[DEBUG ] [Window ] Actual window size: 800x600[DEBUG ] [Window ] Actual color bits r8 g8 b8 a0[DEBUG ] [Window ] Actual depth bits: 24[DEBUG ] [Window ] Actual stencil bits: 8[DEBUG ] [Window ] Actual multisampling samples: 2[INFO ] [GL ] OpenGL version <3.0 Mesa 10.3.2>[INFO ] [GL ] OpenGL vendor [INFO ] [GL ] OpenGL renderer <Gallium 0.4 on NVA8>[INFO ] [GL ] OpenGL parsed version: 3, 0[INFO ] [GL ] Shading version <1.30>[INFO ] [GL ] Texture max size <8192>[INFO ] [GL ] Texture max units <16>[DEBUG ] [Shader ] Fragment compiled successfully[DEBUG ] [Shader ] Vertex compiled successfully[DEBUG ] [ImagePygame ] Load </usr/lib/python2.7/dist-packages/kivy/data/glsl/default.png>[INFO ] [Window ] virtual keyboard not allowed, single mode, not docked[INFO ] [Text ] Provider: pygame[DEBUG ] [Cache ] register <kv.loader> with limit=500, timeout=60s[INFO ] [Loader ] using a thread pool of 2 workers[DEBUG ] [Cache ] register <textinput.label> with limit=None, timeout=60.0s[DEBUG ] [Cache ] register <textinput.width> with limit=None, timeout=60.0s[DEBUG ] [App ] Loading configuration </root/groundcontrol.ini>[DEBUG ] [App ] Loading kv <./groundcontrol.kv>[INFO ] [OSC ] using for socket[DEBUG ] [Base ] Create provider from mouse,disable_multitouch[DEBUG ] [Base ] Create provider from probesysfs[DEBUG ] [ProbeSysfs ] using probsysfs![INFO ] [Base ] Start application main loop[DEBUG ] [Atlas ] Load </usr/lib/python2.7/dist-packages/kivy/data/…/data/images/defaulttheme.atlas>[DEBUG ] [Atlas ] Need to load 1 images[DEBUG ] [Atlas ] Load </usr/lib/python2.7/dist-packages/kivy/data/…/data/images/defaulttheme-0.png>[DEBUG ] [ImagePygame ] Load </usr/lib/python2.7/dist-packages/kivy/data/…/data/images/defaulttheme-0.png>[INFO ] [GL ] NPOT texture support is available
Connected on port /dev/ttyACM1
Sending: B12 I0 J8148.0 K10 M6.35 N3.17 P7560.0 S400 T5 U10 V20 W1 X0 Sending: B03 A1200 C1219.2 Q2308.56 E516.47 F263.15 R139 H79 Y1 Z100 Machine Position Report Command Misread Happened OnceSending: ~ Sending: B12 I0 J8148.0 K10 M6.35 N3.17 P7560.0 S400 T5 U10 V20 W1 X0 Sending: B03 A1200 C1219.2 Q2308.56 E516.47 F263.15 R139 H79 Y1 Z100 Sending: B05 Sending: G21 Sending: ~ Sending: G91 G00 Y-10.0 G90 Sending: G91 G00 Y-10.0 G90 Sending: G91 G00 Y-10.0 G90 Sending: G91 G00 Y-10.0 G90 Sending: G91 G0 X-10.0 G90 Sending: G91 G0 X-10.0 G90 Sending: G91 G0 X-10.0 G90 [INFO ] [Base ] Leaving application in progress… Traceback (most recent call last): File “./main.py”, line 643, in GroundControlApp().run() File “/usr/lib/python2.7/dist-packages/kivy/app.py”, line 792, in run runTouchApp() File “/usr/lib/python2.7/dist-packages/kivy/base.py”, line 481, in runTouchApp EventLoop.window.mainloop() File “/usr/lib/python2.7/dist-packages/kivy/core/window/window_pygame.py”, line 381, in mainloop self._mainloop() File “/usr/lib/python2.7/dist-packages/kivy/core/window/window_pygame.py”, line 287, in _mainloop EventLoop.idle() File “/usr/lib/python2.7/dist-packages/kivy/base.py”, line 324, in idle self.dispatch_input() File “/usr/lib/python2.7/dist-packages/kivy/base.py”, line 309, in dispatch_input post_dispatch_input(*pop(0)) File “/usr/lib/python2.7/dist-packages/kivy/base.py”, line 220, in post_dispatch_input listener.dispatch(‘on_motion’, etype, me) File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/core/window/init.py”, line 645, in on_motion self.dispatch(‘on_touch_down’, me) File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/core/window/init.py”, line 657, in on_touch_down if w.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/popup.py”, line 185, in on_touch_down return super(Popup, self).on_touch_down(touch) File “/usr/lib/python2.7/dist-packages/kivy/uix/modalview.py”, line 243, in on_touch_down super(ModalView, self).on_touch_down(touch) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/relativelayout.py”, line 203, in on_touch_down ret = super(RelativeLayout, self).on_touch_down(touch) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 284, in on_touch_down if child.dispatch(‘on_touch_down’, touch): File “kivy/_event.pyx”, line 316, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4690) File “/usr/lib/python2.7/dist-packages/kivy/uix/behaviors.py”, line 93, in on_touch_down self.dispatch(‘on_press’) File “kivy/_event.pyx”, line 312, in kivy._event.EventDispatcher.dispatch (kivy/_event.c:4636) File “/usr/lib/python2.7/dist-packages/kivy/lang.py”, line 1299, in custom_callback exec(kvlang.co_value, idmap) File “./groundcontrol.kv”, line 212, in on_press: root.openFile() File “/tree/projects/maslow/groundcontrol/GroundControl-master/UIElements/viewMenu.py”, line 25, in openFile content = LoadDialog(load=self.load, cancel=self.dismiss_popup) File “/usr/lib/python2.7/dist-packages/kivy/uix/floatlayout.py”, line 66, in init super(FloatLayout, self).init(**kwargs) File “/usr/lib/python2.7/dist-packages/kivy/uix/layout.py”, line 63, in init super(Layout, self).init(**kwargs) File “/usr/lib/python2.7/dist-packages/kivy/uix/widget.py”, line 173, in init Builder.apply(self) File “/usr/lib/python2.7/dist-packages/kivy/lang.py”, line 1566, in apply self._apply_rule(widget, rule, rule) File “/usr/lib/python2.7/dist-packages/kivy/lang.py”, line 1673, in _apply_rule self._apply_rule(child, crule, rootrule) File “/usr/lib/python2.7/dist-packages/kivy/lang.py”, line 1633, in _apply_rule cls = Factory_get(cname) File “/usr/lib/python2.7/dist-packages/kivy/factory.py”, line 119, in getattr raise FactoryException(‘Unknown class <%s>’ % name) kivy.factory.FactoryException: Unknown class
Apologies for the formatting, but the last line is probably the important one. I haven’t had time to look at the code, but I can’t see anything like this on the forum. Any ideas?
Yes, that was the mucking about I mentioned. I’m allergic to these little bits of stuff. I may sort it sometime in the future. Running with root privs (sudo) isn’t much of a problem with this machine as it’s not really attached to the internet and the machines in the workshop seem to die every year or so, so everything is backed up., It’s a burner machine.
