Everything is calibrated. Firmware is updated. I got the router going, loaded the file and pressed play and got this:
Any ideas what I’m doing wrong?
I’m adding a “save serial” button soon to the UI, but if you can, try to select the serial messages with a mouse(finger if on mobile) and drag up to capture all the messages and see if there is a panic in there or post them here and we can have a look.
Based on the Alarm text above the messages, it looks like something paniced.
You’ll then need to power down, power up, click “alarm” to reset, then in setup, release tesnsion, take the belts off, retract-all, extend all, then reconnect the belts to get back to where you can try again.
Thank you very much for your help. Here it is:
Serial Messages
$/maslow_calibration_grid_width_mm_X=2000.000
[MSG:INFO: Caution: Unlocked]
No heartbeat from machine in 10 seconds. Please check connection.
Alarm
error:8
[MSG:ERR: Emergency stop triggered.]
Hmm I’m not sure what that means: Error 8 is “command requires idle state” ( Error codes are here, BTW Alarm and Error Codes | Wiki.js)
when you started, did you click that “Alarm” button to make it go to “Idle”? It seems like maybe yes as the messages say “[MSG:INFO: Caution: Unlocked]” which would make me think so. What was your order of operations? did the “re-hang dance” as I described, then loaded gcode? did you set your Z home and your x/y home for the job? then just clicked play?
Also, if you try again, you can hit the “test” button on the setup dialog which will spew out some info in the log we can look at too.
please check that you have updated the index.html.gz as well as the firmware to
matching versions. This could be that you updated the firmware but not the
index.html.gz
I’ve updated all of the software.
When I click “alarm” it turns to “idle” and I press play:
Serial Messages
Serial Messages
Index.html Version: 0.71
[MSG:INFO: Firmware Version: 0.71]
[MSG:INFO: Magnet detected on Top Left]
[MSG:INFO: Magnet detected on Top Right]
[MSG:INFO: Magnet detected on Bottom Left]
[MSG:INFO: Magnet detected on Bottom Right]
@bar any ideas? I was really hoping to make this for my mom for Mother’s Day. ![]()
you may want to give 0.72.1 a try.
Also make sure you only have one browser connecting to it during this
calibration process.
Jason Cornelius wrote:
I only remember seeing error 8 if I try to do anything that requires retract/extend/calibrate or retract/extend/tension (I’ve just been thinking about this as the cut-prep process) to have been done first, and only if I haven’t done those things. As soon as I do those, the error goes away.
I’ve managed to get an e stop before going through cut prep, though I forget how.
There is a list of the FluidNC error codes here, but I’d like to work on making it translate them automatically. There is no reason that we need to be giving cryptic error codes when we could be sending human readable messages.
I think that the first thing that we should figure out is what’s going on with the “no heartbeat” messages. It seems like the connection to the machine might not be stable?
