Ian_Tolond: Firmware updates, versions
Maslow 4.1 initial setup
A. Where via the Maslow interfacer can I determine the current version of firmware and key files?
B. YAml file - if this is updated, do you need to re-calibrate (Z axis, also extend all, retract, etc.)
C. Firmware update failure - updating to 1.20 fails circa 42% - there is about 15m between the device and the Maslow unit, with clear space in between (unsure about interference). Would this also cause errors for firmware updates?
A. It should be the beginning of the serial log. failing that go setup then test and it should give you the Index.html version and Firmware Version and a Test result.
B. No. Sometimes you may need to cycle Maslow’s power to force a read. Not normally, if you saved changes correctly.
C. Are you getting a message?
The Green button is where you update files like index.html.gz and maslow.yaml.
To update the firmware you use the Orange button. If you load index.html.gz etc first, when you load the firmware, after it completes it restarts the ESP32 processor and then reconnects the browser.
Solved - it appears I was too far away - when i attempted on my laptop (physically closer) it worked first time
