Anyone found a supplier of the idler sprocket thats not american centric and over priced?
Preferable on this side of the world? Australia / New Zealand
And no Mcmaster does not ship here!!!
EBay?
You should add yourself to the map with the other Kiwis. I’m not one, but we dropped by for 10 days (including a long train ride on the north island and bus/boat trip down south including a bit of snow) last September
not sure if they ship to Australia but they have locations in France, Japan, Canada, and US, so I’m guessing maybe. I just pulled the trigger on some of these for a counter weight setup I’m going to try. they have some much bigger ones too for the same size chain. Ill post how well they fit next weekish. Let us know if you find anything else.
For the first machine before we had them made I just bought regular sprockets and cut off the bit I didn’t need with a hacksaw…it’s not perfect but it worked
You have my condolences.
Found my original source. While that listing is no longer available there should be others, and vendors often use multiple country eBay sites with the same user ID
They must not like chain idlers in Oz, far cheaper to grind off the hub (like $4 instead of big bucks)
Edit: over edited, here it is with the tracking
edit: add pics
These fit the chain perfectly with no altering needed. They do have holes to mount it to a drive hub, but does not come with the hub. They accept a 1/2 inch O.D. bearing. Some router bits I don’t use just so happen to have 1/2 inch bearings on them, so hooray for that. They are aluminum, but as an idler, wear shouldn’t be an issue.
Any luck finding other sources?
