Hi All,
I’m cutting a Podium sign for an Event 2 weeks from tomorrow.
For some reason one of the letters does NOT want to be cut!!
I split the Gcode several times, cut everything but the " E " letter, stops at line 50.
I’m cutting 1/4" MDF with 1mm cutting bit at 1mm pass at 200mm p/min.
I start the cut with Ground Control V.1.20 and thought would be a GC issue then I upgrade to V1.23…
Can someone look at the Gcode and help me out? I have absolutely no idea what is going on!!
Thanks for tracking it down to the line and supplying a shortened file that exhibits the issue - it helps to narrow things down. Both files look reasonable in g-code simulator.
I’ve run the “E” file here with GC and a simulator version of the firmware and it ran to completion, no stops or odd behavior, but let’s keep digging.
Can you describe “stops” in a different way? does GC remain open? If so, does the lterminal output on the right side of the screen say anything out of the ordinary? A screen shot of that terminal output during the “stop” might have clues. A copy (.zip it…) of log.txt might also help.
I’m interested in the right side of the GC screen during the “stop”.
Here’s mine shortly after line 50 ran (sorry for the large picture, you’ll need to click on it to see the whole thing):
There is a setting at the bottom of the Settings page, ‘Buffer Gcode’ Is that set ‘OFF’? If not, could you try turning it off, then quit GC and start again, and try the “E” file.
