I think the answer is ‘yes’ - the firmware now correctly calculates from user settings for the chain pitch and number of teeth, so changing the motor sprocket size should work properly. There is also a user variable for the feedrate limit, set to avoid issues that make one of the motors lag behind the other, as in this discussion. Let us know how it works when you try it!
