And here’s the fix for the toolpath-displayer bugs, it was a small merge problem (of my making), so this is a small rollback, a not so small roll-forward, and a cleanup of some confusion.
Yes, did that several times , it didn’t change the amount it was feeding out. Also tried powering off and and back on. Also no joy. The new Extend Dist was still there but it just ignored it. I have reset to V86, then V88 (original) and it now operates correctly.
I reloaded the V88.1 again and still ignores whatever I set Extend Dist. Tried 150mm with a power reset for M4, still extends to 1.7 mm. If you can think of anything else I can do to help then let me know.
I agree. I initially expected a firmware upload to not change the partition table, but it appears to do so. I don’t know how it does it or the full effects. However, to be safe, I’d advise performing any upgrades or downgrades that affect the partition table using the command-line utilities.
I had that 64k split between the app partitions initially, but they have to be in 4
64kincrements… I’ll add it to the spiffs partition.
Do these partition sizes seem reasonable for the maslow app? It’s hard to predict the future, but it would be nice for users to not have to do a full install again for a long time…
I’ve been working on improving the calibration process so that the UI better reflects what is happening in the background.
To do that I added these buttons over on the right side of the UI which will dynamically change to show just the actions which are available from the current state.
Unfortunately after building this I’ve decided that its not quite right. I think that having those buttons on the home screen is just asking for them to be clicked accidentally.
I think that the right answer is to have those buttons stay on the setup popup, but to better show the current state there and also make it clear which actions are available at the moment there so that’s my next plan.
In the meantime I would love feedback on what everyone’s thoughts are on how the system works and how it could be better.
If you leave dynamic buttons on the front screen, can you make it so you have to confirm (i.e. Continue) e.g. “Click OK to Confirm Retraction” etc.
When you Extend All it changes all buttons to extending, I think Retract all should still be an option on the menu, as I don’t always want to extend all the way out.
Also release tension to still be available. I have to use this multiple times in order to get M4 off the frame as two belts stay tight after the first release and sometimes the second. I do like them on the front screen.
