Hi:
I tried setting the sled up. However, my motors and directions are all reversed. I followed exactly as is specified in these instructions.
front view of frame :
and the rear view :
the connections are as per the instructions :
In the Quick Claibration step, where I specify the orientation of the chain (per image it is Bottom), and per instructions I linked above the motors are connected. After this, when I try to set the gears on the motors vertical (so I can then extend the chain to the necessary length), the direction of rotation is mirrored (clockwise to counter clockwise and vice versa).
Is it ok If I flip the direction of chain from Bottom to Top so the gear rotation directin matches the webControl direction ?
Thanks
