my leeds(wtires) dont extend long enough to fit on my frame
when, in setup i set the size according to my frame
the leads extend to what the machine thinks is enough but this is about 10 centimeter to short when i cance the frame size in setup the leeds still extand to the same length
how do i fix this do’s enyone know??
regards jelle (from the netherlands)
The current v0.88 firmware is more tolerant of dimension sizing inaccuracies. Have you tried just making your inputted frame size 10/20cm larger?
Yes it dosnt matter what size i make the frame de leeds come out to the same length even if i make te frame size small they still come out the same length thats what i dont get or can fix
What is your firmware version number?
And the version number of your index.html file?
I think this could be caused by a mismatch (ie older or newer firmware with an older or newer index.html file)
