Just got my m2 upgrade kit installed and when I move the sled up and down it move the correct distance, the z axis is moving the correct direction and distance, but when I move the sled left it goes right and when I move it right it goes left. Ive tried swapping where the cables are plugged in but then it makes it to where up and down are backwards and left and right are still backwards.
switch the motor cables so they are backwards and the do the $3=4 command to reverse the Z axis.
This sounds like an issue with the top feeding vs bottom feeding setting. Basically that setting sets if the chains feed off the top of the gear or off of the bottom.
Sorry not sure I understand. Swap where the x and y motors plug in? And my z is working correctly so should I still issue that command?
I have it set for top feeding also
