more once i disconnect/reconnect via the USB. I then connected with the WiFi which does not seem correct, but terminal was logging as shown below. Did some commands out of order just to see the log, jog z then went to extend all. Seemed to loose WiFi connection when I started to extend the first belt. I paused when pulling belts but when all were out, last 3-4 lines came in.
FluidNC v1.2.0 using COM5
Exit: Ctrl-C, Ctrl-Q or Ctrl-], Clear screen: CTRL-W
Upload: Ctrl-U, Reset ESP32: Ctrl-R, Send Override: Ctrl-O
Serial port disconnected - waiting for reconnect
Type Ctrl-] to quit
Serial port reconnected
Resetting MCU
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40378016
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-5000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Captive Portal Started]
Grbl 3.0 [FluidNC v3.0.x (noGit) (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:INFO: Center coordinates updated in MaslowKinematics: X=1631.068 Y=1269.591]
[MSG:INFO: Current z-axis position loaded as: 49.000]
[MSG:INFO: Starting Maslow Version 1.12]
00,“tr”: 0.000,0,“ebr”: -0.011,“ebl”: 0.000,“extended”: false}
[MSG:INFO: Current state: 0]
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Requesting state change from Unknown to Extending Belts]
[MSG:INFO: Cannot extend the belts until they have been retracted]
MINFO: { “homed”: false,“calibrationInProgress”: false,“tl”: 0.000,“tr”: 0.011,“br”: -0.011,“bl”: 0.000,“etl”: 0.000,"e}
[MSG:INFO: Succeeded]
[MSG:INFO: Current state: 1]
00,“tr”: 0.000,“br”: -0.075,“bl”: -0.011,“etl”: 0.000,“etr”: 0.000,“ebr”: -0.075,“ebl”: -0.011,“extended”: false}
[MSG:INFO: Bottom Right pulled tight with offset -0.075]
[MSG:INFO: Top Left pulled tight with offset -0.011]
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Bottom Left pulled tight with offset -0.064]
[MSG:INFO: Current state: 2]
[MSG:INFO: Current state: 3]
MINFO: { “homed”: true,“calibrationInProgress”: false,“tl”: 0.000,“tr”: 0.000,“br”: 0.075,“bl”: 0.075,“etl”: 0.000,"etr}
[MSG:INFO: All belts extended to 2005.000mm]
[MSG:INFO: Current state: 4]
MINFO: { “homed”: true,“calibrationInProgress”: false,“tl”: 2017.342,“tr”: 2012.082,“br”: 2019.876,“bl”: 2023.698,“etl”}
