Hey yall,
I have an m2 that I am the 3rd owner of but the previous owners couldn’t figure out how to get it working. I was able to get it working but have only done a couple projects with it. This is my 2nd cnc, the 1st being a foxalien masuter. I’m no expert, but I figured it out.
I’m having an issue with the sled “jumping” aka the motors hiccuping when running across the top of the work space. Basically the motors stall briefly when moving. Both motors do it and at about the same spots everytime. The chains are not slipping or skipping a tooth. And I’ve tried lowering the sled speed and it still does it.
I have a 12’ unistrut top beam reinforced with a 2x4. 15’ chains with a counterweoght sytem. 4x8 work area with wings so the sled doesn’t tip off. Latest version of all software I’m pretty sure. It’s only been about a month of me messing with all of this.
I’ve read that the motors and/or board can get overheated and start acting up, OR when running along the top of the work area, the board can’t handle the power requirement and that causes the motors to hiccup. I’ve ordered a 10 amp 12 volt power supply to see if that’s the issue (oem is 5 amp). But I’m wondering if I can fix this issue with the help of this forum. The FB group hasn’t been very helpful, they try, just not enough people on there.
Thanks for any help!
