Makerverse Login Server not working… Enable GUEST mode
Having issues with Makerverse login because the server isn’t playing nice or playing at all anymore? There is a workaround:
- open your .makerverse file in your favorite editor
- after the first { which is an open curly brace, add this line so it will look like this:
“InsecureDangerousGuestAccess”:true,
save and retry, then when you log in, check the “I understand” box then click Continue as Guest at the bottom of the login window.
