Maslow 4.1 Lubrication
I’m following the YouTube 4.1 upgrade video (using the link from emails) and have a question about lubrication. With the new kit, are there any areas that should receive lubrication during assembly, such as the gear teeth, belt spool teeth, or are where the belt spool contacts the cases? Thanks. I didn’t have a 5.5 (?) mm driver either so used a 7/32nd. Is 5.5mm the correct size for the new nuts?
Is the easy-out you used to extract the motor bolts posted at the end of the video? I didn’t see it in the notes.
Thanks!
Nope! There is nothing that needs to be lubricated during assembly anymore :grinning_face:
We’re not even including the silicone lube in the box anymore.
Adding some grease on the gear teeth would be nice, but they operate at quite low speed so heating isn’t an issue and it would pick up a lot of dust.
This video here?
It should be in the video description.
The easy out that I used in the video is this one: https://amzn.to/3Corvj6
