Maslow started moving in 1 direction during cut
I had hoped to post my first successful project, but at the last moment, the cut failed.
While I was working on my first real cutting project, everything was going pretty well. I encountered some issues with dust catching fire, but I had my router running at speed 4 or 5. After reading some forum posts, I discovered that I should be running it at a much lower speed, like 1 or 2. Is that correct? My feed rate was 400mm/min.
I am using a regular vacuum cleaner with a cyclone separator as a dust collector. Maybe that’s not strong enough?
However, those were not my major failures.
At one point, after cutting for almost an hour on and off, I started a new cut with a new G-code, and almost at the end of the first layer, the machine suddenly started moving in one direction. I couldn’t stop it via the web UI because I received an error stating that my connection was lost (maybe related?), so I unplugged the power.
After rebooting, I was able to move the Z-axis up and release the tension to remove the Maslow from the frame. I noticed some errors in my serial monitor logs about the YAML file being corrupt. However, because I refreshed my browser while trying to reconnect during the failure, I likely lost the logs with the actual error. On the next power cycle I had no more errors about the yaml.
Btw, maybe it’s a good idea to have the option to always log to the local storage of the browser?
Once the Maslow was off the frame, I retracted the belts, but the upper left one didn’t respond. After nearly 20 minutes of multiple power cycles, extending/retracting, releasing tensions, etc., I finally managed to fully retract the upper left belt. Now it extends/retracts normally again, like the other three.
I didn’t find the time to start a new cut. I hope to do so later this week, so I’m not sure if everything is working again.
Any idea what happened here?
My log after the failure:
Serial Messages
[MSG:INFO: FluidNC v0.74 (Maslow-Main-dddcbc15-dirty)]
[MSG:INFO: Compiled with ESP32 SDK:v4.4.4]
[MSG:ERR: Skipping configuration file due to panic]
[MSG:INFO: Using default configuration]
[MSG:INFO: Axes: using defaults]
[MSG:INFO: Machine Default (Test Drive)]
[MSG:INFO: Board None]
[MSG:INFO: Stepping:Timed Pulse:4us Dsbl Delay:0us Dir Delay:0us Idle Delay:255ms]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (-1000.000,0.000)]
[MSG:INFO:   Motor0]
[MSG:INFO: Axis Y (-1000.000,0.000)]
[MSG:INFO:   Motor0]
[MSG:INFO: Axis Z (-1000.000,0.000)]
[MSG:INFO:   Motor0]
[MSG:INFO: Connecting to STA SSID:marzsman]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.2.13]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:ERR: sdmmc_card_init failed code 0x0x102]
error:152 - Configuration is invalid. Maslow.yaml file may be corrupt. Try restarting
[MSG:INFO: Caution: Unlocked]
A picture of the failure
Connection loss is known to cause this issue.
This can be mitigated by connecting to the Maslow’s network instead of using your own, but it can still happen.
also if you can, when you get disconnected, you can capture the serial output in that popup that shows you disconnected. sometimes this has more info on what happened. This is possibly the 15mm error there are other threads in troubleshooting, etc are trying to track down.
With the potential issues relating to connection maybe try USB direct connection?
My understanding from @bar is that usb connection doesn’t/can’t use the WebUI so you need a separate g-code sender (likely app?). I haven’t confirmed myself, but need to look into it.
Bar mentioned universal G-code sender and @ronlawrence3 was experimenting on getting openbuilds control software tested as well. Just seems like testing M4 over USB and with other control software may lead to potential insights on current issues. When I get running in a month I will head down that path…
I’ll try doing this later in the week. Going to calibrate Maslow#3 then need to put mine back together and I’ll have a spare to connect to. Looks like:
Works on Mac so I’ll be able to try it out easier.
I was in panic mode a that moment :sweat_smile:
The moment I hit refresh on my browser I knew I should have copied the serial message first.
The universal G-code sender looks interesting. So, with this app, I can directly connect with USB and control the Maslow4?
I see they also have an ARM build. I was already thinking of installing a Raspberry Pi with a screen close to my frame, instead of walking around with my laptop.
Does anyone have experience with it?
I just found the forum post of @ronlawrence3 about the M4 without wifi. I’m going to read that one first.
I know that feeling well! :joy:
I have not got any further with this, but I may try it again at some point. The laptop I was using for it died and I don’t have an actual computer out in the shop so I’m on an old tablet out there at the moment. I’ve been looking in my electronics scrap bin, and I may be able to get together a pi or an older pc to try it with. I think UGS will work on a pi. not sure about openbuilds control…
at one point you could, but that wasn’t tested for a long time and we think that
the heartbeat messages may have broken this.
So with the latest versions of the firmware we are not sending heartbeat as an info message, and instead are relying on the fluidnc “ping” messages on the websocket for this, so if that was causing things it may be ok now.
From power on, you will however, either have to use the maslow ui to get to the point of being able to run gcode (retract/extend/apply) or run these gcode commands from whatever you are using manually or via macros in whatever software. You certainly will need to have a calibrated machine to even attempt it as calibration calculations are all in the UI.
For a calibrated machine, using gcode sender or any grbl control over usb, does the Maslow firmware support triggering M4 specific commands (extend or retract) via gcode commands?
good to know.
or have some other method of determining the frame size, the manual
‘calibration’ calculation from the onshape doc I created for example.
Yes, because that is what the UI is doing.
However, there isn’t good documentation (other than reading the code) about what
these are and how to use them.
@dlang @ronlawrence3
From the setup dialog I find these in the code:
Notes:
$ALL’,‘Retract All’
$EXT’,‘Extend All’
$TKSLK’,‘Apply Tension’
$CMP’,‘Release Tension’ (AKA COMPLY)
$CAL’,‘Calibrate’
$TEST’,‘Test’
Either of you know if those are $ commands I can send directly?
So far in my life I’ve sent one $ command to a MakerMade M2 last week, but I’m assuming because these are defined in ProcessSettings.cpp as user commands, it should be possible to send from terminal or with macros, etc. function makeusercommands() includes these in Maslow specific section. Finally found the string to search for that showed up in Fluid code base as well are WebUI
I’ll have a spare Maslow to experiment with tomorrow and will update.
Notes:
$ALL’,‘Retract All’
$EXT’,‘Extend All’
release tension and comply should not be the same thing, release tension should
only allow a limited amount of movement, comply would feed out until it stop
moveing
$CAL’,‘Calibrate’
$TEST’,‘Test’
thanks for this, note that calibrate may take the measurements, but does not do
the calculations
you can switch from the maslow tab to the fluidnc tab (the first tab IIRC) and
enterthe commands in there.
Here is the file in firmware that defines all the user commands:
Nice. So how would, say, EXT be called from gcode. $EXT, MEXT?
all the “UserCommand” are $ prefix. so $EXT. Check out the fluidnc wiki for a bunch more $ commands…
