I put this together, I cut the new sled. I put the new sled together, I go to calibrate and the motors will not move. It is connected. When I do the motor test they all fail. Any help would be appreciated. I bought this from Eastbay and I am using the v1.4 shield.
When all the motors don’t work that usually means an issue with the power. Do you see a green light on the board which turns on and off when you plug in and out the power supply?
there is no light on the power supply. Yes I am plugged into the correct board. I am going to see if they have one of those universal power supply things at walmart, see if I can get it fixed.
I’ve had this when the power was plugged into the Mega instead of the Maslow board, and when the power cord of the power supply wasn’t firmly seated (led on the power supply?)
There is no light on the power supply. It is definitely plugged into the correct board because the arduino board power is covered. No power adapter at walmart. I guess I will start by ordering a power supply and take it from there.
