Final assembly of myZ-Axis (based on the design of @MeticulousMaynard). Tomorrow I’ll produce some chips.
Nice. What is the router?
It’s a Kress Spindle.
Kress makes a 110v USA version which is single speed, only their 220v router has varaible speed, Looks like a very nice router too bad not available in USA with variable. speed.
Nice work, very innovative placement of the z axis motor and pulleys. I like those weights too.
this looks really good, thanks for sharing. I’m getting a new sled in a week or so and I need to make a z axis for it. I have several questions:
- Does your vacuum suck down the sled?
- Did you 3d print the spindle clamp?
- How long are your Z slides?
- Do you worry about side-loading the system when cutting (would a second clamp closer to the top of the moving z plate be a good or bad idea)?
Thanks
To place the motor upside down was an idea of @Sylvain_G.
The weights are made of sand casted tin.
Will find that out today ![]()
Yes
250mm
Not that much. But I can easily add an additional clamp in the top.
Thanks @kurt for rewarding me !
Your realization is very impressive !
Good job !
