No COM port found
I’m trying to update to v1.03 via USB.
I have the button pressed down & plug in Maslow.
I run “full-install.bat” & it says “no COM port found”.
I’ve tried 2 different USB cables.
My laptop only has 1 USB port, so I can’t try another.
I’ll see if a can try a different laptop tomorrow, but just checking to see if there is anything else I’m missing?
I had the same issue. I fixed it with changing the cable I think the other usb cable I had was just a usb power cable and had no data. Also I had to double click the full-install.bat file instead of running it from a command prompt window by typing in full-install.bat. If you try and run it via command prompt shell you don’t get the windows security warning.
Hope this helps.
Same with me. I had a bad usb cable, or else it was a power only cable. Once I switch out it detected.
Dano
Ya, I ordered a new cable & it worked.
