In the assembly instructions it says: 6: Select The Serial Port
Select the correct port to connect to by clicking Tools -> Port -> Your Port. On Windows this will be something like COM3, on Mac and Linux computers it will be something like dev/tty/. You can find the right one by plugging and unplugging your Arduino compatible board and checking which option disappears.
I am unplugging and plugging the usb and nothing seems to change in my options (I do hear a ringie dingie each time [sorry if my jargon is too technical]. I went with the only choice that is there whether or not it is plugged in. yet I still get an error message when I try to upload the firmware.
The âwhether or not it is plugged inâ part bothers me. It should disappear when you unplug. Here are some other questions, though I think someone with more knowledge about connection issues may need to take it from here
Is ground control running? I think itâs possible it could be hogging the port, making it unavailable.
What operating system are you using?
What is the error message when you try to upload the firmware?
It sounds like weâre troubleshooting the process of getting the firmware loaded using the Arduino IDE. Iâm not sure which instructions youâre following, but these have pretty good pictures of the menu choices that need to be made in the process. Youâre probably at step 4, but Windows users sometimes run up against a snag. Windows doesnât extract the .zip file when the user opens it unless the user explicitly says to. Make sure youâve extracted the contents of the .zip file and are opening the .ino file from there (this should be step 3.5W maybe?).
Step 6 should list the serial port to use, but plugging and unplugging the cable while the menu is showing might not show the connection/disconnection. Might even need to quit Arduino and start it again for it to recognize the change.
This points out something that I think is a problem. There are a variety of instructions on different platforms. Itâs hard to know which instructions a user is working from and if those instructions are up-to-date.
I have issues with the git wiki to find something that i know is there. This is trying to help someone.
A branch structured menu is the key to where ever it is hosted. My dream would target a â3 click thereâ
I learned that even though I had restarted upon obtaining the latest version of arduino, I hadnât restarted after downloading the firmware. I have made it past this problem (thanks for your help) but there are a couple more things that concern me: 1. Why did I have to get the latest version of arduino when the firmware has an earlier version running on it? as far as I can tell, the latest version I downloaded hasnât needed to interact with the shield. 2. When I went to âActionsâ on Ground Control to select the correct port⌠I selected the port and it gave me this message:
Notification: Unable to find valid position for chain lengths 0.00, 0.00 Please set the chains to a known length (Actions-> Set chain lengths)
â
With every (not always) new version bugs found in the older one are fixed and enhancements added.
It is recommended to have the latest Firmware and GroundControl with matching numbers. (currently 1.18 and new every 2 weeks)
No, I do not see âconnectedâ. also to be fair, you all just informed me that I could be learning from any number of sources, which explains a lot about the gaps my brain has had to fill in . I donât even have experience to know about what to ask next so thank you for your patience. I suppose I am supposed to know what length my chains even means first.
Feel free to ask anything any time.
I would not expect that you see the message from GroundControl without being connected, so you cracked the first hurdle I guess. Keep asking and you will be making woodchips soon.
Going further Windows may need additional drivers to properly see the Arduino Mega. After the drivers it is a matter of identifying the correct Comport in Device Manger then plugging that into the Arduino IDE. Itâs a Chicken and Egg situation.
In addition to @Geroâs point about improvements to the ArduinoIDE, it helps ensure that the screens, menus and selections match our online documentation. It helps us provide support as well - âall on the same sheet of musicâ sort of thing.
Well, thatâs a victory, in a way⌠when GC makes successful contact with the firmware, the firmware reports current status to GC. The firmware keeps track of where it thinks the router bit is by storing the amount of chain it has extended on the two motors, and a similar value for the z axis if that is present. This information will be preserved through power cycles and firmware updates. When it isnât present, the dialog you saw comes up. In practice, that would only happen when the machine hasnât been calibrated, when the EEPROM has been wiped as a troubleshooting step, or when the Arduino Mega has been replaced. Once youâve been through the calibration steps, the firmware will have valid values for the chain lengths and youâll not see that message againâŚ
So, the message means that GC is using the correct port and that the firmware is present and running on the Arduino Mega. Now on to the calibration, and youâll be making wood chips very soon. Keep us posted and bring up suggestions for ways to polish the process.
