Just starting out and spent half an hour chasing my tail because I set the belt length longer than the actual belts. Wondering if it would be good to have a flag or a note for the maximum belt length as it is constrained by the physical size of the machine? I don’t think it is possible to stuff any more belt in there. Not a complaint, just noob error and suggestion. Would it also be possible maybe with a noob button to have ranges for the config numbers visible? Wonderful machine and thank you for your work on it.
That is a great suggestion, I will add that!
Hey @wouldchuck, did you use Anchor Point Layout Simulator when planning your layout, would a note/warning there have helped save you some time/effort?
Hello @AzaB2C I did use the anchor point layout simulator which is very cool but I don’t think it would have helped there. Really it was my own dumb mistake but it seems like the config dialogue is where I would have noticed that I had put an extra zero it to an absurd belt length. I had suggested a limit there as the current machine can’t work with any more belt than fits on the spools.
