As you guys know, my biggest concern with the optical calibration approach has been the question of how you get an accurate grid to start with.
I just ran across this video https://www.youtube.com/watch?v=Xi9raT8gyEE which points at this $230 (plus shipping) kit that shows how you can make a very accurate grid without having precision equipment in your shop.
that’s a bit pricy for the kit, but it got me thinking about what’s really needed here.
you need:
- a way to drill straight holes
- at least two guides that have evenly spaced holes, at least 5 holes at the spacing you want the resulting marks (the longer the better, as long as you have at least 3 holes across your minimum distance and 4 across your maximum distance) The exact hole spacing doesn’t matter, what matters is that the holes are all in a straight line and the spacing between them is exactly the same (both on each guide, and the guides match)
by definition, we have a router that can be used to drill straight holes, or you can use a drill press, or a drill guide ( such as https://www.rockler.com/portable-drill-guide or even https://www.rockler.com/jig-it-drill-guide)
to make the holes the same distance along the guides:
make a positioning jig. The jig needs to have a flat board (say 1x4) as the base, a little longer than what you want the hole spacing to be, and a rail along one edge (ideally the thickness of your guide material, or 2x the thickness so you can create two guides at once)
position a temporary fence to allow the jig to move side to side, but not at right angles to the rail
clamp your guide material to the jig against the rail (and the rail against the fence), drill a hole through the guide material and the jig near one end. put a pin through this hole (the tighter the fit the better[1])
unclamp the jig and slide it down the rail the distance you want the holes to be spaces, clamp the jig down well (it will not need to move again, so you can screw it down) and drill another hole.
pull the pin, slide the guide material down so the hole you just drilled is over the other hole, put the pin back in, drill the next hole.
repeat step 5 until you are at the end of your guide pieces.
now follow the directions in the video to drill the holes. In our case, we don’t need the larger holes, so we don’t need the second jig shown in the video[2]
I know there were more problems seeing the holes than seeing crossing lines. that can be dealt with by either increasing the contrast, backlighting the holes, or putting a target in them (either a visual target or a grounded target to probe). at least you are starting out with an accurate target grid.
I’ll try to make some pictures of what I’m talking about in the next few days, but there are others here who make better pictures than I do
[1] to increase accuracy, you should either use a guide material that your drill is not going to distort as you are drilling the calibration holes, or you could drill the holes larger than your pin and use bushings like https://www.atlasbronze.com/product-p/s841bsf-816-10.htm in the holes. I would suggest getting something like https://www.homedepot.com/p/Everbilt-96-in-x-1-in-x-1-4-in-Aluminum-Flat-Bar-802547/204273941 or https://www.lowes.com/pd/Swanson-Tool-Company-Straight-Edges-6-ft-Metal-Ruler/50438214 or go to a metal supply house and get a 10’ length of aluminum or steel bar, or use a bunch of bushings in wood
[2] if you do want to make larger holes, make another guide piece that’s wide enough to mount your router on (with the same hole spacing as your guides, so remove the rail from your jig and use a fence to keep lined up) that’s at least 4 holes long. mount your router to this new guide piece so that it’s exactly lined up with one of the two center holes, fasten the router base to the guide. now you can put a 20mm or a 3/4" bit in the router and plunge though the guide to drill your holes. start off as shown in the video, but instead of needing the special offsets, get/make a head on your pin that exactly matches your larger holes (something that looks like the small pins shown in the video). if you have a small hole in your workpiece, use the small end of the pin as shown in the video. If you have a large hole, put the large end of the pin in the hole, with the pin sticking up for your guide, it will hold things in place.
P.S. with the news of the Pi 4 coming out, it occurs to me that the pi camera module v2 is 8k, and it’s very flat. so it would be easy to 3d print a holder for it that had a 1/2" shaft to mount in the router. put a pi on the sled with the camera, talking to a pi running webcontrol via wifi, you should be able to use the off-the-shelf video tools to track the hole and tell you their coordinates, and you can calibrate it by drilling a hole, keeping the router in place (clamped down if needed) while you replace the bit with the camera, and looking where the camera then sees the hole (you need to keep the camera from rotating, but with the wide ribbon cable of the Pi camera, that’s easy enough to tape down)
