Given that we have people making the horizontal/vertical mistake, can we auto-detect if we are vertical?
if we put all 4 arms in comply for a couple seconds and the machine moves, that should tell us we are vertical (and which way gravity is, in case it’s not really the ‘top’ arms on top), if we are horizontal, the weight of the belts shouldn’t change, right?
if we are under a lot of tension and horizontal the belts may move a bit to relieve tension, but only a bit.
I could be wrong about this, but it seems like we should be able to tell the difference.
so its clear for all, assuming a good calibration was already done, what are the actual names of all the variables that a user needs to update/copy over to the new yaml file when updating firmware?
Seems possible to me. maybe before the “apply tension” or “calibrate” step in the initial process… I think doing this in vertical orientation could be “surprising” to a user though with the sled dropping a bit.
what about only doing the check if it’s set to be horizontal?
what happens if you are set to vertical when you aren’t. how can we detect that?
I think that seems like a good idea. I think I need to set myself up a smallish horizontal frame so I can experience it. I have not even seen how things behave on this at all, so Bar might have a better answer.
