Today was the first day that I have ever cut plywood; before I’d always used MDF.
I’m using an M4 with a spindle that can go up to 10000 rpms (same as @dlang has). On my first test cut at full speed the plywood burned a bit.
I reduced the speed but it’s hard to judge just how fast it’s going. I ran some cuts but the result wasn’t good. I’m thinking that i have to increase the spindle speed but somehow find the point where it doesn’t burn.
I noticed that the sledge jittered about a bit and wasn’t smooth during cuts.
The plywood is 10mm thick and I was doing 2mm deep each pass.
Any tips?
