I really like using Krabscam to generate Gcode and to organize the pieces in the work area, but I see that there are certain limitations in the tool diameter that the only decimal it allows me is N,5 and for the target depth the only decimal it accepts is N,3. Can I change these values for more precise ones? For example, I am using a 3.17mm cutter but it only lets me put 3.5mm or 2.5mm and for the target depth I want to put 18.5 it only lets me 18.3mm or 19.3mm.
Hmm, that’s surprising…You should be able to put any number in there.
Just by clicking on the number and editing.
Browser related perhaps?
I’m using firefox and chrome and it works just fine for me.
This warning must be issued by the browser. What browser are you using?
I’ve changed the inputs to accept any ‘step’-size, so you will hopefully get rid of the problem after reloading the application.
I use google chrome with duck duck go
I think I was confused by the valid measurements prompt and was trying to scale my model to match the “offset” in my tool.
It’s wonderful, thank you
