What version of firmware and software are you using? I just upgraded to v1.12 on both, and have seen that error during the “measure motor spacing” routine (which I have done several times in the last 24 hours to try to solve some chain length issues). I am pretty new at this myself, but have not seen that error in the earlier versions I have used (v1.10 and 1.11). In my case, the machine stops when the message appears, and it is not possible to follow that instruction. After the error recurred, I exited and re-entered Ground Control, still had the problem, and then tried resetting the computer (which I think also resets the Arduino board). That helped me, but I haven’t gone as far in the cal routine as you. Hopefully later this AM I will get through the whole process. If this proves to be a recurring problem for you, I would suggest going to v1.11 for both firm and hardware, as I did not see that error there.
Hang in there, read the forum, and take a break when you feel like pushing the thing out the door!
Does the z-axis motor run without lowering the router? That has been a common problem.
You can test to see if this is the problem by applying light pressure to the back of the router when the z-axis is lowering. If that works, then you can run a bungee cord over the top of the router to apply constant pressure that helps the router down.
Here are some examples of how others have fixed this.
Thanks for the reply, the router does move… and when I hit raise and lower and set the mm depth the unit moves well…
It just seems that when I set the zero… and the unit goes to cut… it raises the router first but then does not plunge to a cutting depth it seems to just plunge back to zero…
I’m thinking it’s all within the settings of ground control as the axis does move freely
It might be worth noting with the Ridgid routers some people need to use a bungie cord over the top of the router to assist it in the downward direction.
Can you post a ful picture of the router/ sled/ Z axis?
