I was having trouble retracting one of my belts, Didn’t look forward to pulling arm apart to try and identify the problem, so I decided to repack the belt.
Procedure:
- Set retract value to 200
- Extended belt to max
- Retracted - belt did not move as retract value too low
- Extended belt again, this time belt was extended all the way out, could see empty spool in arm.
- Blew out the arm with air pressure to remove dust
- Reset Retract value to 600
- Did retract again, this time retract drew the belt all the way in.
Now Maslow is running with a retract value of 600
