I managed to add a folder to fliud called “index.html.gz”
leaving it impossible to install the actual “index.html.gz” file
Can’t delete the folder
can’t change its name
however i have heard the is a way to reset the files.
I have found the “full_install.bat” file
I just don’t know what to do with it
Help?
All that you need to do is to plug a USB cable into the port on the controller board and into a windows computer. Then just double click full_install.bat and everything will be re-programed to factory new
Scroll down until you see that “SD Files” Section.
The delete / trash can icon should remove the files, but sometimes its a bit finicky so if you are deleting from the top of the list, hit refresh to make sure the list is current before deleting again…
