I have a file/cut that stalled the WebControle M/Rpi.
I want to start where it stopped. I found the line no : 54621.
If I put it into the # field and tap ‘goto’ I can see the cursor move.
But I can not get any action pushing ‘PLAY’.
Where should I look for errors ?
What do I do wrong ?
the problem is that you need to first run the first few lines of the file, then
you may be able to skip down to the point where it left off (it depends on if
the file is made using absolute or relative movement commands)
i usually use the Z> button and go to the nearest Z move and then hit play and it generally works… if the motor power supply is connected. I have a switch for that and it isn’t always on.
yes the 1> is next line, the z> is next z move. watch on the screen, the black crosshair will move to show you where it is. easy to move it to that, then just press play.
