Seems like a lot of users are experiencing problems due to RF interference. Would it be possible to print the PCB mount and cover using conductive filament to create a Faraday cage around the electronics?
Problem with that is that the Wifi would also be blocked
That said, I’m thinking we could have one between the board and the router as long as the wifi antenna is clear of it (next to the metal part – ESP32 – on one side of the bottom of the board)
I’m thinking about trying this in addition to the new firmware and grounding my shopvac hose.
Will you try just the new firmware first? I want to see if we’ve fixed it in software because it might not be an issue anymore.
It was infrequent enough before that I’m optimistic we’re not too far off from a solution
Yep, missed that part.
