Rvt to svg or gcode
I have found a design online, but they have it available in rvt format. I dont have autodesk. or a shopbot. Does anybody know or have a way to load a rvt project and export the files to svg?. is there a way to generate a cutable gcode from rvt files?
thanks
There seems to be no “free” direct route. From a DWG to SVG is possible. https://www.safe.com/convert/ifc-revit/dwg/
What is the file about? A clean screen-shot from an online viewer and then using the trace bitmap function could also get you there if there are not to many details.
do you know of an online viewer where i can trace it out
https://viewer.autodesk.com/ but you need an account with autodesk. Did you download the rvt file?
