Hello all,
I am having issues getting set up. I’ve tried a few times, and searched the forum here and a few other sites, but I just can’t get it done on my own.
My main issue now, I think, is with the board. I have a Maslow Complete Basic Kit, so it’s the Arduino board that comes with that. I think I was on the verge of finally getting calibrated after troubleshooting a few issues. Before I was able to get calibrated, I decided to drill a hole in the top beam to insert a bolt to hang the sled. Well, I am a dope and forgot that the arduino board is mounted on the back of the top beam!
So I hit the back of the board with the drill. I can’t believe there is no visual damage (I was pushing pretty hard).
Now the right motor fails the test, and doesn’t move at all. That motor works when it is plugged into the left port. I also switched the cords, so I’m pretty sure it’s a problem with the port (Port 1) on the arduino. I also noticed the Arduino (not the motor controller shield) has a yellow light lit when I plug it in. I don’t remember seeing the light before I hit it with the drill, but I’m assuming it should be green.
Can I fix the Arduino? Do I need to get a new one? Am I even asking the right questions? (Yikes)
