Im looking on the Maslow website, under the guide step 5.
In step 8 it says the Design files for the sled can be found in the file section.
I download the file, has an awful lot of photographs and other non opening exe. but no NC of GCode?
Can someone point me in the right direction please?
bar
#2
Thank you for pointing that out. I will look into it right away. In the meantime I recommend this one as an actually better alternative:
http://maslowcommunitygarden.org/Sled-With-Center-Alignment-Jig.html
bar
#3
You are right that there is not currently a gcode file in there for the sled. I will add one right away
bar
#4
I’ve created a pull request here to add a ready to cut gcode file
Many thanks, I will use the recommended.
