Don’t know if this is the right area to post this but here it goes. I finally was able to clean out my garage and make space for the maslow that I ordered last year. I went thru the assembly guide. Setup my electronics. Programmed the Arduino. Installed the latest ground control which i think will be updated soon as there seems to be an issue with the last step (Test Cut). Somehow a window is not showing up and freezing the process to make a test cut and measurement afterwards. I found that out thru a previous post. So I moved on and built the new frame made of 2x4. I’m finally at the final step which is cutting the final sled. Finally, here is why i made the post. Is there a another file that already have all the holes that are needed for the R22002? The new sled design seems to be made for the ring which is another item i do not have and doesn’t seem to have the holes to screw in the router on. I already purchased the z-axis machine which i’m waiting shipment on and the Triangulation Kit. Any help would greatly be appreciated. Thanks!
Thanks for the response! I will do that with my router base. I checked the files in the community garden and i’m not seeing the sled for the L brackets i got with my machine. Now i ordered mine a while ago and received my package last year but i wasn’t able to build it till now. I’ve seen post with the L brackets i have and i just can’t find the svg or dxf files with the holes for the L brackets. Probably outdated. Let me know if i’m just being blind lol.
based on this reply - it may be out of the realm - On occasion I want to reply with 1 word or 2. Is there a easy way we can add, a pad function, to add 01234567890,09876543210 to short replies. I get tired of counting. Sad I know.
A while ago I learned that when you post an emoji using the colons (:), each character in the emoji name counts toward the minimum number of characters. It also turns out that there are a few emoji whose names are long enough to reach the minimum. stuck_out_tongue_winking_eye, for example.
