Sled movement opposite of controls in ground control
maslow%20board
The control board is mounted on a cross member on the rear of the setup. I used the ‘Bolt on Frame’
Do you have GC set for chain off top or chain off botom. Should be chain off bottom else for your setup sled will move opposite of what you want.
I did not see that setting. Where do I find it?
Settings, Advanced Settings (button at top) and then its something like Chain Off Sprocket… options will be top or bottom. Make sure it’s bottom based upon how your frame is built.
Title is Top/Bottom Chain Feed
I set it to bottom and every GC action causes it to go down. I am going to re-measure the chain and see if that helps
The sled is moving correctly. TY
