It’s possible this has been asked before, but I can’t find it so maybe it hasn’t.
I’ve downloaded the svg file for the sled template from here on Github and imported it in Autodesk Viewer to check the dimensions. The distance from the center (router bit) to top alignment hole is slightly less than the distance from the center to the left and right alignment holes. Distance to top measures 6.201-inches and distance to the left and right measure 6.251-inches. 0.05-inches is small, but it’s still a difference. Are these distances correct for the ring? I’m making my own drilling template to build the new sled by hand and I want to make sure I get it right…
