Just got everything mounted on the final sled, I didn’t have the motor mounts tight enough and didn’t realize they had been pulled over, looked away for a split second and the chain come off the left motor, sled hit the floor. I straightened motor mounts and started the calibration process again, but now my left motor spins out of control when I do 1 deg, 5 deg etc. Is this something I can fix before I order a replacement motor and sprocket?
double check that the connectors are plugged in all the way.
I feel like a total idiot, that solved the problem.
it’s a common problem.
