Trouble connecting to the wifi
i have connected twice
using the maslow wifi and the maslow.local
I then updated the files
they wouldn’t fit so i zipped the firmware.bin and the index.html.gz changed there names back again
uploaded them and now i am unable to connect either way… when connecting to the maslow wifi on my phone i get a an error occured. the page could not be opened
is there a way to connect via a cable?
Yes, you can connect by USB. Make sure the usb cable is a data cable and not just power. The files you need are in the latest release and how you do it depends on whether you are running a Windows or Mac PC.
See the following video and substitute the latest version where it says version 1.0 (V1.21 is the latest)
(56) Installing Firmware 1.0 - YouTube
This does a complete replacement of the operating system. Any GCode files will not be affected.
You will find the latest version here
Releases · MaslowCNC/Maslow_4
The file you need to unzip is one of the highlighted ones
fluidnc-maslow4-1.21-posix.zip for the Mac and fluidnc-maslow4-1.21-win64.zip for windows
This should get you back to the factory setting
To upgrade in future the two files you need are index.html.gz (do not unpack) and firmware.bin and they are loaded using the 1st Green button under the FluidNC tag for index.html.gz and the orange button for firmware.bin
