NEW setup - booted - connected to Maslow- downloaded 1.20 (firmware, YAML and Index.html.gz)
followed instructions (updated all 3 files- commencing with Firmware (all ok), then Index and yaml - rebooted, now I can’t connect to the webserver/ Wifi?
Are you connecting via a LAN? Check to see if you have a Maslow WiFi connection. Did you setup the WifI SSID (Setup, Config), if so you should now have a blue led flashing, and you should be able to connect via your LAN, with maslow.local or the IP address for Maslow
try netstat -n and look for local addresses. Maslow should be one.
