In South Africa they dio not have the Rigid Router or its equivalent. My router did not fitt inside the orginel ring so I had one made at 300 mm ID 330 OD and mounted as per pic
Mounted Z axsis no issues there simply changed value in the seetings too -1.975
did all the setups and changed the setting table to the following
Com3
2975.96
2438.4
1219.2
428
369.5
184.75
79
on
-1.975
I was able to move the x-y axis in Ground Control
Got to the set-up “test shape” 5 cuts and ran it
It moved to the left but not the correct position did a cut
Moved lower to the left did a cut
these are the approx measurements
Cut 1 from top edge of board 525 and 505 mm from the left edge of the board
Cut 2 from to edge of board 685 and 275 mm from the left edge of the board
It then traveled up and towards the center. It traveled past the top edge of the board – so I hit stop
I then decided to redo the entire setup again and noticed that the left-hand motor had wrapped up the chain. I released both chains and did a top dead center for RHS motor tried the left and it would not run
On inspection of the board, I found that the main chip had totally blown for the LHS motor
A new shield is on route to me; thanks Hannah
Clearly, I am not understanding the setting when deploying a larger ring
If there is anyone who could assist me in understanding the settings/measurements needed when using a 300 mm ring. I have used approximately 34,75 mm as the distance from the roll edge of the ring to where the chain attaches
Looking forward to working with you all
