Using Makerverse and today it stopped recognizing the workpiece home, instead uses global home
Yesterday I wanted to a quick project and found that my Z-axis stopped working with Makerverse. I think it was a user error in that I left the power supply to the mega shield plugged in all week. At first I thought I had lost the shield but after testing the Z using ground control it started working but I lost my calibration in Makerverse. I re-calibrated and all appeared fine except the system will no longer recognize work piece home. When I bring gcode it shows it at the work piece home location but when it runs it works from the global home. Any ideas on a quick fix? Or do I need to re-flash the firmware and re-calibrate?
Thanks
