So after seeing some states get cut I had to add mine to the list (one of the hardest profile I know). This cut was a test for pocket operations, z-depth and a tool bit change (1/4 to 1/8). Let’s just say I’m still learning. Things went slightly better than the last time but realized my Z-axis set screw came loose half way in and my depths got a little screwed up. I tried to turn the inconsistent depth look into something I did on purpose by adding what I hope is a “realistic” look. You think it worked?
